Hi, look in your electric book, which servo is for X Y and Z? Or give a picture of the electric cabinet.
MAZAK Service, servotek.gmbh@gmail.com
i have a new to me Mazak VTC20B -96 with Mazatrol M plus control.
Servos: HA83NC-S
Drives: MDS-B-V1-10 and MDS-B-V2-1010 (dont know which one controls what)
occasionally my X axis servo starts humming when motion stops, it will go away after 10-15 secs or instantly if i move the axis again. Load % goes up when humming occours.
Normally at idle my X load is 4-6% higher than the Y axis.
Any advise on what to check?
Gustav
Ok, what alarm code you get on this servo?
Are you able to look at the machine parameters?
Ok please find the SV parameter.
Ok, try to change SV38 on X-axis down from 150 to 100 or 70. Get it better?
Try it
Check lubrication, then thrust bearings. You may need servo tuning, but that is a waste of time unless the mechanicals are good.
Sent from my SM-T813 using Tapatalk
