Originally Posted by
semenov419
Goodday Hemmanth
Thank you very much for pointing it out. As for wires it was kind of let's see what happens thing, that eventually pinpointed the problem. So at this point we are soldering everything back as it was and changing the settings.
As for the other problem, we do have one, and given the opportunity may be you can help resolve it.
This same machine is equipped with 12 station power turret by Lioshing. Once in a while it was giving us a problem with zero position, where we would have to set it again and again. (M77 tool magazine maintenance mode, M29 - M83 Unlock the turret, rotate turret to the zero position mark, M84 lock then implement zero return M74, machine reboots and whola it's set - but once in a while we had to go in to diag menu and use modal output to control X227 lock, x228 unlock, and y224 commands since M codes would not work, on top of that we would be missing alarm messages on the screen even though controller would have one blinking). Well while dealing with the spindle problem, we ran in to the issue where turret stopped changing tools, when given the command, X and Z axis would move it to the set position, then turret unlocks and nothing happens afterwords, meaning that servo will not rotate the turret to the set tool, but rather unlocked turret will rotate under the weight of the heaviest tool and that is just about it. In the mean time controller blinks with A90 alarm (zero return not complete) and once in a while A25 alarm. We tried setting zero position with the method described above but we can not get past M84 command. When implementing M84 turret will not lock, thus we can not implement M74 command that sets zero position. Again and again we tried with no result, began checking the wires and indeed found one bad contact that was fixed, but besides having all the messages appear on the screen (i mentioned that we were missing alarm messages from the turret) this did not do much for the issue itself. I did play with X227 x228 and y224 and could have messed up the settings, looking at the latter monitor it seems that those commands are backwards, but I am not a pro to claim it the right reading. Also while playing with X and Y commands couple of times we had a message servo resistor overheat - so i am thinking may be the servo went and that is where our problem is.
Thank you in advance.
