Is yours Mazatrol M32?
Hello
I started retrofitting this machine assembled in 1989 in UK and encountered trouble with the rewiring.
The machine came without the electrical diagram.
I did remove from the machine FC335M NC controller.
X, Y, Z axis driver MR-S1, MR-S11 and servo motors.
The parts removed are useless to me if anyone needs them let me know maybe we can trade something for the electrical manual.
I installed:
MR-J2S 750W servos instead of the old HA-83C .
Mesa 7I77 card with 5I25.
I need the wire map of INPUT and OUTPUT from the board BB21A, BN624A942H01.
Can I get some help with the BB21A pins/connectors?
Razvan
Hello,
Our NC was a M32. We did remove it and we use one PC with LinuxCNC.
Razvan
Thank you for the answer.
The board in your drawing is the same with the one on my machine..
I need the pins/wires that are connected to that board to connect them to the Mesa 7i77 board.
We did replace the Mazatrol M32 because we got a parity error. I did exchange all the boards on NC controller and did not found the problem.
Thank you,
Razvan
Retrofit progress:
Here is the machine cabinet with exchanged servo drivers and NC.
I did prepare the machine for five axis. I did install one Granite Argon servo driver capable of driving old HA83C servos for testing only. I will replace it with MR-J2S-70A later on.
And the naked machine after a lot of cleaning and cleaning. It was extremely hard to remove the dried deposits of oil and coolant.
Razvan
Very good job! Congrats.
I also had problems with the control.
Send me your e-mail, so I will send you some electric manual pictures.
Sorry, I do not have enough time to take pictures to the hole manual, so I wiil try to help you, as much I can.
help me me podrían pasar el diagrama VQC15/40 ELEMENTARY DIAGRAM BN065C043 F01-1
Eleazar, creo que puedo ayudarte. Me pasas tu email o whatsaap por mensaje privado ?
Enviado desde mi GT-I9500 mediante Tapatalk
Did you get electrical pictures from somewhere? If you got it, could you send me a copy? I need to find the machine i / o ports. mail: kemppainen@live.fi
Best Regards,
Tuure Kemppainen
I buying also vqc 15,and i also want change controller,else my trasformator is broken..
Good morning, could you also send the electrical manual, thanks
cocilova.f@tiscalinet.it
