VQC 20/50b - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: VQC 20/50b
  1. #13
    Registered mazak-user's Avatar
    Jan 2011
    Slovenia
    Default Re: VQC 20/50b
    You must do initialisation of the control.
    Gesendet von meinem SM-N910C mit Tapatalk
  2. #14
    Sep 2012
    First thing to do is disconnect the batteries or remove the jumpers. Then make sure that the capacitors are totally discharged. Check them with a multimeter and get as close to zero volts as possible. Reconnect the batteries or the jumpers. Now do a re-initialise then reload parameters. Should be good to go then
    Regards Bob
VQC 20/50b
VQC 20/50b
