Hello xa-mont. Which turret (4, 6, 8,12 tools)? Tailstock included?
Hey guys,
I'm looking at getting an 86 mazak quick turn 10n with a T2 controller.
This will be my first CNC lathe and the jobs I have lined up for it will be fairly simple to start off with. I have a very small amount of experience with mazatrol, but seems easy enough to learn.
Is there anything in particular that I should be looking out for on it?
Cheers,
Trav
Here's a bit of info about it:
Chuck dia 210mm
Draw tube dia 46mm dia
Spindle bore capable of 51 dia
Max work piece size
250 dia 500 mm long
Tool setter.
8 tools on turret
Hi pressure coolant pump
Programable tail stock
Swarf conveyor.
Quality machine in excellent
Condition.
Sounds like a good find. I have the same machine and wonder about it's lube and way oil consumption.
Hello guy, do you have the parameters for this machine? I have a Mazak SQT-10 with mazatrol T32-B and batery died. Thanks a lot!
Hello, i have all for Mazatrol T2. Please write what you need. My machine is Mazak QT10N
co.cnc.biuro@gmail.com
