Machines with one port use the same one for CMT and tape mode. Cable pin out may be different also. CMT uses null modem, some tape ports use direct serial connection. This applies to M32A controls. M32B controls do not have EIA, only Mazatrol.
Probably a stupid newbie question but, a question none the less. Where is the tape port on an M32 control? I've got a VQC 15/40. CMT from control to PC is working correctly but, no tape mode.
Any thoughts?
MrMazak,
Thanks! Any tips on setting the machine up for tape mode?
Not sure what you mean by the above. Connection via a Null Modem cable is directly connecting the Serial Port of the External Device (PC) to the control.Originally Posted by MrMazak
The term Null Modem is a generic term and refers to any cable where the complementary signal lines (TD and RD) are swapped and simulates the connection between a DTE and DCE. For example, you can have a cable that has:
1. No Handshaking
2. Loopback Handshaking
or
3. Full Handshaking
and all are referred to as Null Modem. The term Null Modem harks back to its origin as a cable that bypasses the computer-to-modem (DTE to DCE) connection and directly connected two computers (DTE to DTE)
The Loopback cable is the configuration that's most often used with machine tools. This configuration gives the illusion of Full Handshaking, when in fact there is no Handshaking at all. When using a Loopback Handshake cable, handshaking is via control characters, primarily DC1 and DC3. Notwithstanding that the corresponding Xon Xoff Handshaking Method is set in control parameters and PC software, these control characters are not read by the communication software, but at system level by the Uart.
As you have comms successfully working between the PC and Cantrol, you probably have the settings at the control set correctly. However, just to be sure, they should be as follows:
User Parameter No 2
G19 = 2 (4800 Baud) (Suggested Starting Point)
G20 = 3 Stop Bit (This gives 2 Stop Bits)
G21 = 0 Parity Even Parity
G22 = 0 Parity Check Invalid
G23 = 3 number of Data Bits for Reader/Puncher 8 Bits (IMPORTANT)
G27 = 1 Placement of CR for ISO Punch
G29 = 3 Handshake DC1, DC4 Codes (Software Handshaking used with Loopback Null Modem cable)
G42 = 200 Wait time
User Parameter No 4
I1 = 2 (4800 Baud) (Suggested Starting Point)
I2 = 3 2 Stop Bits
I3 = 0 Parity selection
I5 = 3 Data Bit selection
I6 = 3 Handshaking selection
I7 = 1 Parity added to DC code
I8 = 20 Seconds for Time Out Duration
I9 = 0 No output of DC2 or DC4 (DC1 = Xon - Ascii 17, DC3 = Xoff - Ascii 19)
Configuration of the PC software when using a Loopback Null Modem cable should be as follows:
Handshake Method = XON - XOFF (Software Handshaking)
Baud Rate 4800 (Suggested starting point)
Parity = Even
Data Bits = 7
Stop Bits = 1
1. Its important to note that Data Length set at the Control is 8 Bits and No Parity, but the PC software should be set for 7 Data Bits and Even Parity. The reason for this is that the Mazak control counts the Even Parity Bit as a Data Bit.
2. To do direct DNC, set the I/O Base Param for Data In, Data Out N/C Running (Direct DNC) according to the Device number and its associated name.
Regards,
Bill
What? I don't follow at all. Are those settings on the PC side or the machine side of things?
Also, I'm getting two alarms:
1) 887 TAPE I/O ERROR
2) 548 NO EIA/ISO OPTION INSTALLED
My guess is that they're related. Is there a way to tell which version of the M32 control is installed?
On the Machine side. There's an I/O Base Param page for setting Data In, Data Out device number and associated name.
Your Control does not have the EIA/ISO (Text) option. Accordingly, DNC of G Code programs is not available.
Regards,
Bill
Bill,
Thanks, I guess , for the info. I guess that means I'll be looking for a Mazatrol native CAM solution.
Hi everybody,
I am a new user with an old problem.
In fact I try to save / load programs from Mazatrol M32, but till now don't works.
I have try several combination of settings on board and on pc programs, but noting.
I use the Cimco V5 or Cadem to trasfer data.
The DNC function don't seems to work, so I have test with CMT and Tape, but I receive the 515 Error message.
I think my problem is in the CNC settings, so I found this forum.
I the earlier post I have seen some settings for " User Parameter No 4
I1 = 2....", but In my on board setting page for User Parameter No 4 I have the axes settings, like I1 = axis x, I2 = axis y, I3 = axis z, ecc.
My question is where I can set the CMT or Tape settins?
Thanks for help!
Hello,
I am fairly new to the cnc machining and am trying to transfer program to my Mazak VTC 20c with mazatrol m32 control.
I get the Error 553 Tape Reader Error during the transfer.
It randomly shows up during the transfer. Its not always in the start of the program or at the end of the program but random.
Would you be able to help please.
I use Cimco Edit v5 to send the program.
Gurneet
Czesc, wiesz moze gdzie znalesc parametry I na mazatrol m32b? Pozdrawiam
Czesc, wiesz moze gdzie znalezsc paramtery I na mazatrol m32b? pozdrawiam
Hello, I'm looking for parameters I on the machine VTC 20b on the control Mazatrol M32B, but unfortunately I can not find
