Need Help! Mazatrol M32 sub programs not registered
Results 1 to 6 of 6
Thread: Mazatrol M32 sub programs not registered
    Aug 2010
    australia
    Default Mazatrol M32 sub programs not registered
    Hi
    When I make a simple drilling and tapping prog on my VMC Mazak with mazatrol M32 control, it gives me a following alarm.
    "844 not found prog no"
    "An attempt was made to call sub program which was not yet registered"
    "Action: Register sub program"
    Can any one advice me how to register the sub programs or I am missing any data or parameters.
    Apr 2008
    Make your sub program first.
    Aug 2010
    australia
    Thanks MBI.
    Any example how to write a sub program for tapping.
    Apr 2008
    You may be confusing a program and a sub program. they are the same thing. Make a Mazatrol program of your tapping unit and put a end unit on it. Make another Mazatrol program containing a subprogram unit in it. place a offset unit in the main program before the subprogram unit and then you can offset and/or rotate the subprogram.
    Jun 2015
    Quote Originally Posted by mbi View Post
    Bumping an old one here but I'm having the same issue. Alarm 844. Made another mazatrol program containing the sub program but no success. When you say put an offset do mean a wpc? Or do i put the wpc in the drilling program and an offset in the main program? I have attached photos of the 2 programs. Any thoughts?
    Attached Thumbnails Attached Thumbnails Mazatrol M32 sub programs not registered-20170311_121200_resized-jpg   Mazatrol M32 sub programs not registered-20170311_121211_resized-2-jpg
    Apr 2008
    Default Re: Mazatrol M32 sub programs not registered
    Quote Originally Posted by Leemac View Post
    In Pro 2
    Line 2 remove repeat (make it blank)
    Line 3 (end unit) make it all zeros
    Pro 1 ok
