Mazak M32 system disk backup
Results 1 to 10 of 10
Thread: Mazak M32 system disk backup
    Aug 2005
    indonesia
    Default Mazak M32 system disk backup
    I wish to make back up copy of Mazatrol M-32 system disk.
    System disk is not readble on PC.Is there any utility to read and make copy of system disk.There is no menu to make a back up from system .
    Another problem i noticed is the Floppy drive used on the controller is not compatible with the standard pc floppy drive(though they appear to be same) .I tried exchanging with with new 1.44 floppy drive and it is not at all reading?
    Thanks in advance for any help and suggestions.
    rgds
    sivaraj
    Member wjbzone's Avatar
    Apr 2003
    If the disks you have are the same as my Mazak disks, they are formated with a special Mazak system. You can buy software that will run on a pc that will read these disks, but it is expensive. (at least the software I have found)
    A simple utility to copy these disks would be a big help.
    I am currently looking at buying a software package from http://www.solution-ware.com/. It is a CAM package that allows Mazetrol programming from a PC. Has many nice features like generating G-code from the Mazetrol program, Mazetrol printouts, file organization, converting programs from M32 to M2 etc.
    Another package I looked at is Mazak Camware. I don't think this had as many options (Like being able to generate G-code).
    If there are other options, I would like to here about them.
    Bill
    Mar 2005
    Silicon Valley, CA
    wjbzone,
    Check out this from Griffo Brothers. Its another popular one for PC programming in Mazatrol.
    It's just a part..... cutter still goes round and round....
    Sep 2005
    We have an old copy of solution-ware that I use at the shop, it does a nice job of converting the programs from t-plus - t-32 and etc. (same for the mills) I have used it for some programing but not much. It helps alot around the shop, really helps if you have several different types of mazaks in the shop(we do)
    Mar 2006
    INDIA
    you r right shivaraj
    but you can note all the system parameters manually
    Dec 2008
    india
    Default parameter problem
    Quote Originally Posted by ravin View Post
    hi sir,
    Roshanlal is this side can you tell me how we enter the parameter in mazatrol T-plus.thanks in advance.
    roshanlal74@yahoo.co.in
  7. #7
    Nov 2010
    india
    Default MAZATROL M32
    HI
    I AM RAJENDER FROM DELHI. IT SEEMS THAT YOU HAVE GOOD KNOWLADGE OF MAZAK .I HAVE MAZAK AJV 35/60 WITH MAZATROL M32 CONTROLLER .WE NAEED TO HELP TO RUN THE MACHINE ,ANY SUGGESTION IS APPRECIATED.
    MY ID IS parshad.r@gmail.com
    Regards
    Rajender
  8. #8
    Oct 2017
    India
    Quote Originally Posted by parshad.r View Post
    HI
    Regards
    Rajender
    Mail me your problems to my mail id sudhakaryerva@gmail.com
  9. #9
    Sep 2017
    Bahrain
    Default Re: parameter problem
    @roshanlal For M-PLUS you can manually enter from the hard copy or through RS232 if you have the soft copy
  10. #10
    Nov 2017
    Viet Nam
    Default Re: Mazak M32 system disk backup
    hi
    i can
