Results 1 to 10 of 10
Thread: Vibratory for aluminum polishing
    MBG
    MBG is offline
    Feb 2005
    uSA
    Okay, I got an ultra-vibe 45 from thumler's tumberl.
    I got all the heavy scratches out.
    Now, I bought fine walnut shells I don't believe it has rogue.
    I been running the parts in the vibratory for about 16 hours so far.
    It isn't working.
    Please help. Trying to get a finish like this.
    http://www.glacern.com/sols_blog
    Aug 2004
    You need the rouge to get that finish. Do you a pic of parts as they stand?
    Thanks,
    Paul
    MBG
    MBG is offline
    Feb 2005
    uSA
    Okay, an update.
    I got the walnut with special treatment.
    C & S sales set me up. It has been in the vibratory about 15 hours and no luck.
    PLEASE HELP!
    Registered BobWarfield's Avatar
    May 2005
    MBG, a couple thoughts from my own experience.
    Not sure the rouge you're using, but I have had good luck with walnut shells impregnated with green rouge, available from Grave's. It sells in smaller lots if you have a smaller tumbler.
    Second, it's really important to use something a little coarser to get rid of the big scratches. I use 3/8" styrene triangles from Grainger.
    For 6061, I leave the parts overnight in the styrene triangles right after they come of the mill. When they're done there, I move them on to the green rouge. I have noticed the finish will continue to improve if you leave them in as long as 4 days. 48 hours seems to be about the minimum for my tumbler.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    MBG
    MBG is offline
    Feb 2005
    uSA
    Quote Originally Posted by BobWarfield View Post
    Cheers,
    BW
    Thanks, what type of tumbler do you own?
    May 2005
    Lyman 1200 Pro
    MBG
    MBG is offline
    Feb 2005
    uSA
    Lyman 1200 Pro
    oh wow that is a really small one.
    And you are able to get a polished finish from aluminum? If so, I should have no problem with my ultravibe-45 model.
    May 2005
    Look about half the size of your ultra. The bigger they are, the faster they polish, all things considered. Of course, sometimes that just means your standards go up too, LOL.
    Got a friend with one that's probably twice your size. He still leaves his parts in for 4 days. Talk about looking like mirrors!
    One thing I will probably do is buy a second one so I don't have to keep changing media.
    At some point I'll have to try some anodizing too.
    Cheers,
    BW
    Apr 2007
    MBG
    MBG is offline
    Feb 2005
    uSA
    Cheers,
    BW
    4 days huh? I haven't left them in that long yet.
    Yes, anodizing is fun but very difficult on a larger level. If you do it stick with the 5 gallon bucket set up. I did that for a while and it was easy.
    When you get into bigger set up like my 40 gallon tank you get into electricity problems, cooling, heating,. Everything is differnet and needs to be designed properly.
    1. Help in Vibratory Polishing of Bearing Steel
      By Prasham in forum Mass finishing equipment/media/stratigies
      Last Post: 03-04-2011, 11:27 AM
    2. Vibratory Finisher For Polishing Aluminum
      By SCzEngrgGroup in forum Mass finishing equipment/media/stratigies
      Last Post: 12-11-2009, 08:34 PM
    3. Need Help!- Vibratory Polishing Washers...?
      By tof1 in forum Mass finishing equipment/media/stratigies
      Last Post: 07-19-2008, 07:48 PM
    4. Recommended vibratory media for Aluminum
      By SRT Mike in forum Mass finishing equipment/media/stratigies
      Last Post: 03-30-2007, 08:46 AM
    5. Vibratory polishers and aluminum
      By jkeyser14 in forum General Metalwork Discussion
      Last Post: 05-16-2005, 04:11 PM
