Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Mass finishing equipment/media/stratigies
Mass finishing equipment/media/stratigies Discuss Mass finishing equipment/media/stratigies here!
Old 04-11-2009, 01:40 AM
dang's Avatar
dang is on a distinguished road
Cheap DIY Bowl Tumbler
After a gruelling 3 day build, I've at last bested those familiar cutting edge devils with my finished parts tumbler. I'm poor as shux for project bucks, so this deal had to ring up at less than $15.
I turned every stone on the interweb and found Don Ashe's plans here.
http://www.buildgear.cjb.net/
For the bowl I used a halved 14" tire from a children's ride on monster truck. It's connected to the base, a bucket from Home cardcheck, err Depot, by 4 spring loaded posts. The motor is a super tiny 110V with a bit of steel turning eccentric, and sports a custom adapted aluminum cradle. It's been running strong, about 5 feet away from me for 2 hours now. It's quiet in tumbler terms and the sonic monotony ain't too bad either, sorta comforting actually.
All this for under $15. I'll build three more in the upcoming weeks. I currently use Lizard Litter crushed walnut shells, available in pet stores as tumbling media. It's aaight.
ID:	79493   Click image for larger version
ID:	79494   Click image for larger version
ID:	79495   Click image for larger version
Old 04-11-2009, 09:13 AM
paul gibson is on a distinguished road
Excellent! Always delighted by simple,effective little projects like this. What material are you deburring in it? And would the 2 hours run time be the same batch, or multiple batches? Time away from the files and belt sanders is always time well spent.
P.G.
Old 04-28-2009, 05:19 PM
dang's Avatar
She Sells Sea Shells
I've experimented with different sorts of super cheap tumbling media for deburring. I've tried the crushed walnut shells, pebbles and now I'm trying out crushed sea shells, which look like they're gonna work well. I'll update later with results.
Another DIY Tumbler Ted383 Mass finishing equipment/media/stratigies 28 07-10-2011 01:44 PM
Mirror finish steel and aluminum parts vibratory bowl? Toggle Metal Finishing and Plating 1 01-06-2011 08:06 PM
how do i cut a bowl with bob-cad jrslick22 BobCad-Cam 10 12-12-2007 02:17 PM
CNC a dome/bowl without CAM software? NotDylan General Metal Working Machines 2 04-03-2007 10:29 PM
Homemade bowl tumbler, media for Al polishing bob1112 Mass finishing equipment/media/stratigies 4 03-27-2007 03:15 AM
