Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Mass finishing equipment/media/stratigies
Mass finishing equipment/media/stratigies Discuss Mass finishing equipment/media/stratigies here!
Old 07-16-2008, 04:48 PM
tof1 is on a distinguished road
Vibratory Polishing Washers...?
I'm trying to polish some stainless 1" x 1/4" fender washers in a vibratory polisher. The first step I'm using ceramic media flushed with plain water. My problem is I can't keep the washers from sticking together while vibrating. Does anyone know a trick to keep them from sticking together? Thank you!
Old 07-18-2008, 08:06 PM
Old 07-18-2008, 11:53 PM
cjdavis618 is on a distinguished road
Do they they feel magnetized when you seperate them?
Old 07-19-2008, 11:45 AM
Harryman is on a distinguished road
Put a small amount of glass beads used for bead blasting in with the media, it'll get between the washers and break the suction. You don't need much and you'll have to add more as you lose them when draining/rinsing the tank.
www.harryhamilldesigns.com
CAD sculpting and services
Old 07-19-2008, 07:48 PM
No they don't.
I'll try that. Thank you for the suggestion!
changing belville washers duphus Fadal 1 01-23-2008 04:02 PM
changing belville washers Shizzlemah Fadal 1 10-19-2006 11:48 AM
RFQ: Aluminum Washers kellogs72 Employment Opportunity 4 12-24-2005 10:48 PM
machining washers MBG General Metalwork Discussion 6 03-10-2005 02:44 PM
RFQ: Washers kellogs72 Employment Opportunity 4 02-21-2005 07:00 AM
