Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Mass finishing equipment/media/stratigies
Mass finishing equipment/media/stratigies Discuss Mass finishing equipment/media/stratigies here!
Old 04-30-2008, 05:16 PM
twocik is on a distinguished road
6061 aluminum finish ??
6061 aluminum part
I wanted to know the best way to put a nice shiny finish on my new part. I surfaced the part on my CNC mill, but don't like the boxed swirly pattern that the end mill left.
I don't own a surface grinder, but I do have a 12" disc sander and a 6" grinder. I have 120 grit paper for the 12", but don't think this is really going to leave me with a nice shiny finish.
Any tips or help would be greatly appreciated !!
Old 04-30-2008, 07:24 PM
Anyone ?
Old 04-30-2008, 07:27 PM
ger21's Avatar
Depends on the shape of the part, but I'd wet sand with 320, 400, 600, and then polish with polishing compund.
Old 04-30-2008, 07:33 PM
But doesn't that scratch it, leaving a nasty surface?
I'll upload a photo of my part, give me a sec.
Old 04-30-2008, 08:27 PM
You'll notice in one of the pictures the stair stepping on the side of the part. I believe this is do to my backlash screws loosening. The part I'm trying to surface is the top of the shaft and maybe something to clean up that side.
ID:	58762   Click image for larger version
ID:	58763   Click image for larger version
Old 05-01-2008, 11:36 AM
Kevin Taylor is on a distinguished road
Make a flex pass using cuter comp or wright a tool path to do the same to clean up the steps a vib finisher will camo some of the tool mark's but not all two flut end mill fast spindel speed coolant and a fairly fast feed rate on the cleanup Good luck kevin
Old 05-01-2008, 12:24 PM
peburrell is on a distinguished road
I found out about a neat tool that might help out. I was helping out with FIRST last year at a machine shop and they had a semisoft wheel that went on a grinder. They referred to it as a deburring wheel. It almost acted as a polisher. It will remove a little material if you are not careful.
Doing a quick web search it looks like 3M might also make something using scotchbrite material. I know that you can get this in sheets, so maybe put it in a sander.
Make sure you try it first on a sample piece.
Paul
Old 05-01-2008, 10:03 PM
Thanks guys for help and suggestions, but I have already found a way that worked great. Here's what I bought
- 180 grit wet sandpaper
- 800 grit wet sandpaper
- 1200 grit wet sandpaper
- 2000 grit wet sandpaper
Started off with the 180 and worked it all the way thru the 2000 grit. I then polished it with some mothers aluminum polish, and bam the part came out looking like it was chromed ! Couldn't be happier with the finish, except how easy the surface scratches.
I started another post here asking what can I do beside anodizing or painting to seal it. Any at home tricks I can do ?
Old 05-02-2008, 01:07 AM
austin.mn is on a distinguished road
Paul
Don't ever use those if you intend to polish the part to a mirror like finish. The problem is that unlike using sandpaper you end up putting scratches in the parts that have an inconsistant depth. So even if the part looks nice and shiney you still end up having a lot of work left sanding to prep them for buffing the part to a mirror. They do put an alright finish on the part from the get go though. So if you are planning on painting or powder coating the part they are excellent.
Old 05-02-2008, 11:41 AM
Thanks for the tip !!
Here's a picture of how it came out. Notice the scratches on the bottom of the shaft, not from sanding. I had the part backwards in the slot and must have moved it up and down a few times, and as you can see scratches scratches.
Anything I can do to prevent this, maybe a little clear coat from Lowes, home depot ?
  #11   Ban this user!
Old 05-02-2008, 01:24 PM
baltman is on a distinguished road
I always found Pledge lemon furniture polish ok for keeping the aluminum from oxidizing. Might stink a little but it works
  #12   Ban this user!
Old 05-02-2008, 06:29 PM
jpgdesigns is on a distinguished road
ZoopSeal
Best milling finish on 6061 SRT Mike General Metalwork Discussion 17 03-31-2011 10:35 AM
Need Help!- Mill Bit 6061 aluminum Ed Williams General Metal Working Machines 3 03-16-2008 11:45 PM
Problem- Very rough finish when turning 6061-T6 ... why? cnczoner General Metal Working Machines 18 03-16-2008 06:24 PM
Getting best surface finish OD turning 6061 AL? SRT Mike General Metal Working Machines 14 09-17-2007 11:57 PM
Help - Cutting Aluminum 6061 dfranks DIY-CNC Router Table Machines 50 11-18-2005 04:32 PM
