Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Mass finishing equipment/media/stratigies
Mass finishing equipment/media/stratigies Discuss Mass finishing equipment/media/stratigies here!
  #13   Ban this user!
Old 05-03-2008, 08:49 AM
tikka308 is on a distinguished road
Check out my thread here: http://www.cnczone.com/forums/showthread.php?t=56994 it also has a link to my blog where I'm working on teaching/experimenting myself with 6061 finishes and will continue to post updates as I play with different solutions!
Tormach PCNC 1100, SprutCAM, Alibre CAD
  #14   Ban this user!
Old 05-03-2008, 06:00 PM
Red Frog is on a distinguished road
Wink polish
Polish the piece with methyl ethyl ketone. Toxic but removes any oxidation.
  #15   Ban this user!
Old 05-03-2008, 10:39 PM
Update - I swung by a local Jewelry Supply store (Metalliferous in Manhattan on W 46th St - www.metalliferous.com - highly recommended) and purchased some 1200 and 2000 grit sandpaper. I also purchased 400 and 600 grit sandpaper along with MAAS polishing creme at HomeDepot. Fully details - including a tutorial video of the process - are available here: http://www.nyccnc.com/Herbie/HERBIES...uminum!!!.html
Bottom line: I have achieved a great looking mirror finish on aluminum!
  #16   Ban this user!
Old 05-04-2008, 11:59 PM
twocik is on a distinguished road
Hi Tikka,
I've done the same exact method in my picture posted two days ago (400, 600, 800, 2000, then the mag polish). My problem is after I sanded, polished and so forth, the part still scratches like cheap glass.
I've read that when anodizing there is some chemical _________ ? that leaves a scratch resistance surface, almost like a clear coat of some sort.
Do you have any videos on how to DIY anodizing ???
Parts List ??
This would be a great video to put up, going thru every detail on that. I would have already tried this, but I'm just afraid I'll burn or electrocute myself.
Nice job on the video btw very detailed, I just wish I would have found this 4 days ago.
Chris
  #17   Ban this user!
Old 05-05-2008, 08:02 AM
Twocik - I hear you. I'm trying to achieve the same thing you are - which is a clear, protective finish over my parts. I just purchased Rustoleum's Aluminum glossy metalic finish , which is an enamel spray (http://painting123.com/ProductInfo.asp?p2=I2 product #446637). I tried it with high hopes, but it has two flaws: 1) It foggs up the mirror finish (not completely, but enough that it bothers me) and 2) it doesn't REALLY protect it! A very very light touch fromi a piece of metal scratches the coat. Now, scratching this is better than scratching the polished aluminum, but it's still not a solution I am content with.
I have never done DIY anodizing but am VERY interested. If I had a "real" workspace (i.e. not my bedroom), I'd be doing it tomorrow. I ultimately think anodizing is the only / best solution, as it truly provides a HARD protective finish...
  #18   Ban this user!
Old 05-05-2008, 07:08 PM
Twocik - I just email with a guy at DuraCoat. He said that their product will 1) provide sufficient protection from scratches as a hard-protective layer and 2) not impact the aesthetic of the part. I'm going to order this - http://www.houtsenterprises.net/product119.html - and you can count on me to post the results on my blog www.nyccnc.com
  #19   Ban this user!
Old 05-05-2008, 07:28 PM
Baketech is on a distinguished road
The best spray on product for bare metal that I have found is Nyalic...YMMV
  #20   Ban this user!
Old 05-07-2008, 01:45 AM
Let me know how it works out !!!
So no one on the home DIY anodizing ?
Part lists
  #21   Ban this user!
Old 06-18-2008, 08:50 AM
destroyer125 is on a distinguished road
Best Home anodizing tutorial out there.
http://www.focuser.com/atm/anodize/anodize.html
I do anodizing at home, Cant say im small scale anymore thought.
Quality Type 2 Anodizing PM me For a quote!
Examples of our work here! http://s74.photobucket.com/albums/i260/125Customs/
  #22   Ban this user!
Old 11-01-2008, 11:37 AM
CASWELL PLATING DIY ANODIZING KIT
Seems very cheap and the guy is saying that it's safe.... ? Plus it comes with a instruction DVD !!!!
The things still needed to compelet the kit
- Power supply
- Odds & Ends
- Battery Acid
The only thing that thru me off was the coloring. Mix you own colors, not really sure how that works, but I guess this is explained in the DVD...
Any thoughts on this kit ?
http://www.caswellplating.com/kits/aluminum.htm
Best milling finish on 6061 SRT Mike General Metalwork Discussion 17 03-31-2011 09:35 AM
Need Help!- Mill Bit 6061 aluminum Ed Williams General Metal Working Machines 3 03-16-2008 10:45 PM
Problem- Very rough finish when turning 6061-T6 ... why? cnczoner General Metal Working Machines 18 03-16-2008 05:24 PM
Getting best surface finish OD turning 6061 AL? SRT Mike General Metal Working Machines 14 09-17-2007 10:57 PM
Help - Cutting Aluminum 6061 dfranks DIY-CNC Router Table Machines 50 11-18-2005 03:32 PM
