- New Machine Build- home made vibratory tumbler
hello, i started making vibratory tumbler, something as rosler fba 24. Dimension of bowl is 700mm diameter and 460mm height. Motor is 0,75kW 1420rpm. I took some old valve springs and machine seats for them. I progress very good, weld some frame and bowl and now i need to machine spindle, bearing housing and make weights. Im planing to put some dosing pump for cleaning compound
- You may not post replies
- You may not edit your posts
Forum Rules
