CNC Machining,Milling,Tunining,Drilling, Planning, Grinding, Welding From China
Results 1 to 3 of 3
Thread: CNC Machining,Milling,Tunining,Drilling, Planning, Grinding, Welding From China
    Member konwey's Avatar
    May 2017
    China
    Talking CNC Machining,Milling,Tunining,Drilling, Planning, Grinding, Welding From China
    We are China machining parts, metal stamping parts, turning parts, cnc parts, Springs, coldforming parts, machining parts, screw machine parts, casting parts, forging parts supplier, We can produce machined parts according to your requirements.
    Machining parts: Hydraulic, Valve, Fange, Automobile, Shaft, Bearing Housing Bar, Plate, Welded Part, Marine Part, Winch Part, Sheet Metal.
    Equipment: Common lathe, CNC Machine, Milling, Turning, Stamping Machine, Spring Machine.
    Metal Process: CNC Turning, Mlling, Drilling, Planning, Grinding, Welding.
    Surface Treatment: Zn (Cr3 RoHS free or Cr6 ) plated, Cr /Ni plated, Hot-dip galvanizing, Paint, Anodize, Powder coating, Brush, Polish.
    Technical: Dedicated mechanical designer, experienced worker 3D design service inclusive of modeling, analysis and detailed drawing at normal cost
    Quality: ISO 9001: 2008
    Control strictly and follow specification move fast to meet your urgent need caused by accident.
    Packing: Wooden case, Hardboard, Steel pallet, according to custom’s requirements.
    If you want to know more about machining parts in China, Please contact us.
    kon@cncmachining.cc
    www.cncmachining.cc
    Jun 2017
    Default Re: CNC Machining,Milling,Tunining,Drilling, Planning, Grinding, Welding From China
    Sorry my reply has been deleted because it was posted on the wrong thread.
    Sorry
    May 2017
    China
