Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > Manual Machining Tooling
Manual Machining Tooling Discuss Manual Machining Tooling here.
Old 04-28-2008, 08:17 AM
JeffreyCNY is on a distinguished road
Arrow Seriel Number stamping or engraving
I need to stamp or engrave serial numbers on a serial plate I plan to order. Does anyone have any experience with this? Which works best?
$10 single number set?
$150 set with 8 place holder?
Rotary Stamp?
Pantograph Engraver?
Outsourcing to a local trophy or jewelry shop?
Handheld vibrating engraver?
Ordering finished from plate supplier?
I feel this is a real easy problem to solve but experience is usually the best advise. I would like to know what other people are doing. I need to do less than 10 a week so expensive machinery is probably not an option.
Old 04-28-2008, 12:03 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
My local trophy shop as extremely reasonable for items such as this.
If I am doing CNC milling on my parts, I will engrave the # while it is setup otherwise I prefer parts to be stamped.
Another method we use (if stamping is inappropriate) is to engrave with a Dremel using a small round burr (or diamond if the part is hardened).
www.integratedmechanical.ca
Old 04-30-2008, 04:35 PM
apache405's Avatar
apache405 is on a distinguished road
I would stay away from the hand held engraver, unless you have a VERY steady hand.
-Jeff
Old 06-24-2008, 08:19 PM
rando's Avatar
rando is on a distinguished road
http://www.etch-o-matic.com
check this out....we use it all the time. don't buy the neutralizer, have found vinegar works better.
Old 06-25-2008, 02:43 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
That looks neat! I make stainless lens hoders that have to be serial numbered- that looks a lot easier than my current method of stamping- the stainless is very hard and doesn't like being stamped. Thanks!
I love deadlines- I like the whooshing sound they make as they fly by.
Old 06-25-2008, 06:06 PM
rando's Avatar
Be sure to neutralize the acid. If you do not, your picture perfect number will turn to a big ugly rusty scar!
Old 06-26-2008, 04:41 AM
ImanCarrot's Avatar
Cheers for the tip- I got stacks of Sodium Hydroxide and Potassium Hydroxide here (about 30 gallons)- the guys in the coating plant use it for some arcane process so they should know how to handle it.
swipe stamping? Med-Pac Diemaking and Diecutting 4 01-25-2009 01:34 PM
Metal roof forming stamping? DennisCNC Bending, Forging,Extrusion... 7 06-28-2008 09:49 AM
Number Counter CI_182 G-Code Programing 3 09-01-2007 03:41 PM
Stamping letters in alum in CNC mill clujan General Metalwork Discussion 2 07-16-2007 08:10 AM
stamping MBG Bending, Forging,Extrusion... 47 10-19-2005 07:48 AM
