Look about 3 sub forums down for the Workholding forum. You'd more than likely get a quicker answer there.
Mark
Hi
I'm new to the forum and have no idea where I should have posted this question so I thought here would be a good a place as any.
I work for a small pattern making firm where I operate a Haas TM2 3-axis mill. 95% of the things I make on it are foundry patterns and composite tooling machined from PU and epoxy tooling boards.
More often than not, to mahine a job I usually end up screwin it to a wooden base board of mdf or plywood and then clamping that to the table.
For a while I have been interested in using a vacuum table for workholding but am totally unsure of how to aproach this.
So far I have expremented using a workshop vacuum, a table made from PU tooling board and a neoprene rubber seal. I think the principle is there but the vac is totally insuficient.
I have NO idea when it comes to pneumatics etc about pump sizes and all that lot. I want to be able to plough through tooling board at 4mpm with a 42mm cutter at 5mm depths without it flying off the table is my goal. What size pump/tubing etc should I be looking at? What kind of vacuum pressure etc?
Help would be HUGELY apreciated.
Mark
You will run into some issues with your tooling board being porous. WHat densities are you using and how big are the pieces? On a commercial 4'x8' wood router with a vacuum clamping system you will see anywhere from 20hp up past 50hp. That should give you an idea of what you need. A "shopvac" is not going to do it.\
Matt
