Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Spindle thought
    Feb 2012
    England
    Spindle thought
    I have two 750w B&D routers which I don't use now as I have an Ryobi 1500w.
    Anyway these B&D routers are similair in body shape to those Kress router/drill.
    When under load these tend to be a bit noisy and was pondering whether it be the plastic casing they're housed in? so it got me thinking about sandcasting a round body in aluminium and house it in this,plus better bearings to suit the armature shaft.
    Anyone think that an aluminium body would dampen the noise a bit bearing in mind the thickness of the wall of the housing will be about 3mm or 4mm
    Feb 2012
    England
    This is the fella,the body can detach from the base.
    Registered Christian Knüll's Avatar
    May 2010
    Germany
    Changing the casing won't help - the noisy part is the fan.
    To improve noise you need to get rid of the fan without killing the spindle due to overheating. You may think about attaching a silent blower on the outside with a duct leading to the venting holes - however this will look quite a bit strange.
    CAM Software and open source CNC controller: www.estlcam.com
    Dec 2003
    Quote Originally Posted by Christian Knüll View Post
    To improve noise you need to get rid of the fan without killing the spindle due to overheating..
    Your rpm may go way up, the off load rpm is restricted by friction and windage only, the Universal motor operates in a run away condition.
    Feb 2012
    England
    Forgot about this thread....
    Anyway the KW800 doesn't have a blower fan....
    Black & Decker KW800 Type 1 Router Spare Parts | Miles Tool & Machinery Centre
    I'm guessing that the plastic body and possibly the bearings are the suspect of noise?
    Feb 2012
    England
    It has a speed controller on the top,Al
    May 2010
    Germany
    the fan is directly below the rotor:
    I don't know about the B&D but a Kress won't run away with removed fan - they have closed loop speed control.
    Dec 2003
    Quote Originally Posted by HorridHenry View Post
    Yes but the maximum rpm would still go up, the built in speed controllers do not offer great control, you would need something like SuperPID for that.
    It would be unusual if there were not an internal fan blade on the armature itself.
    It is a similar to covering the output of a vacuum, you are essentially removing the fan from the load and the RPM can be heard to rise drastically.
    Feb 2012
    England
    How quiet are treadmill motors? I been given one and pick it up tomorrow.
    I know they're 180v not too sure if thats DC or AC? this ones 1.7hp which is decent for a spindle.
    Feb 2012
    England
    Pretty quiet than the afore mentioned router.
    They're quite heavy and weigh around about 8kg but thats down to the iron flywheel housing that takes the treadmill belt drive,once this is removed off the shaft spline it becomes less weight and is adequate for a CNC spindle or a better mini-lathe motor.
    Jan 2006
    The treadmill motor is only turning a few thousand RPM with substantial torque while the router is much higher speed with substantially less torque. To put them in the same class, you could gear up the treadmill motor with belts and pullies, but then you have to have a spindle with its own bearings.
    Matt
    Feb 2012
    England
    Hi,Matt
    I knew the treadmill motor is only 4200rpm opposed to the router at 28000rpm?
    The intended thing was to drive a spindle on a pully as you stated.
    I got it for nothing so will not lose out and so its either use on the lathe or CNC whichever suits the motor better?
  • Page 1 of 2 12 LastLast
    1. Just thought we'd say hello
      By Valen in forum Australia, New Zealand Club house
      Last Post: 08-01-2010, 06:41 AM
    2. Modified X2 Spindle thought.
      By BSawyer486 in forum Benchtop Machines
      Last Post: 05-31-2010, 10:33 PM
    3. 15 Min left, thought I'd point out this spindle!
      By Hdale85 in forum DIY CNC Router Table Machines
      Last Post: 10-02-2009, 08:17 PM
    4. Thought I better say Hello
      By Nigel_B in forum Australia, New Zealand Club house
      Last Post: 09-06-2006, 07:50 AM
    5. Cheap spindle thought
      By Hobbiest in forum DIY CNC Router Table Machines
      Last Post: 07-07-2004, 09:48 PM
