Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Spindle thought
  1. #13
    Dec 2003
    Quote Originally Posted by HorridHenry View Post
    How quiet are treadmill motors? I been given one and pick it up tomorrow.
    I know they're 180v not too sure if thats DC or AC? this ones 1.7hp which is decent for a spindle.
    The vast majority are DC, although I have seen a Universal motor with rpm/tach control on one, one thing to watch out for is some have offset brushes making them uni-directional, usually the cheaper ones.
    The KB/Baldor drives on ebay are a good candidate for a drive.
    Be suspicious of HP claims, they often would not run at the rated hp in a sustained mode.
    Jan 2004
    NEW HAMPSHIRE
    I have found that using a router for sustained usage will burn it out relatively quickly. Yes they are ungodly noisome. I have a treadmill motor and a variable controller from Supluscenter.com, but its weight has made some build/strength issues in the past. If you don't mind over building your machine it gets my vote for a quieter cooler machine.
  3. #15
    Dec 2010
    United Kingdom
    Spindle Idea
    Most noise from spindle motors is down to balancing, if the spindle and tool is perfectly balanced, including the collet nut, then noise should be to a minimum,
    Www.emachcnc.com
  1. Just thought we'd say hello
    By Valen in forum Australia, New Zealand Club house
    Last Post: 08-01-2010, 06:41 AM
  2. Modified X2 Spindle thought.
    By BSawyer486 in forum Benchtop Machines
    Last Post: 05-31-2010, 10:33 PM
  3. 15 Min left, thought I'd point out this spindle!
    By Hdale85 in forum DIY CNC Router Table Machines
    Last Post: 10-02-2009, 08:17 PM
  4. Thought I better say Hello
    By Nigel_B in forum Australia, New Zealand Club house
    Last Post: 09-06-2006, 07:50 AM
  5. Cheap spindle thought
    By Hobbiest in forum DIY CNC Router Table Machines
    Last Post: 07-07-2004, 09:48 PM
