Results 1 to 3 of 3
Thread: 208V 3 phase power
    Apr 2007
    New York, NY
    208V 3 phase power
    I just moved into a new shop with 208V 3 phase. My previous shop had 230V single phase with a rotary phase converter. Actual measurements in the new shop are 213V between phases and 120V to neutral.
    Nothing except my TIG is explicitly rated for 208V. I have several 3ph motors (Bridgeport, air compressor, lathe, grinders). I'm also about to begin retrofitting a CNC milling machine.
    What do I need to know?
    Dec 2003
    Especially being a bit higher than 208, you should not experience any problems.
    What machine and controller are you retrofitting?
    Apr 2007
    New York, NY
    You are so helpful you can't even remember all the people you help! Tree Journeyman 320 B Retrofit
  1. Need Help!- VF5 208V conversion?
    By machinist007 in forum Haas Mills
    Last Post: 08-04-2010, 08:18 PM
  2. Build Thread- 3-phase power
    By pvellenga in forum Phase Converters and VFD
    Last Post: 07-12-2009, 10:58 AM
  3. 3-Phase power help
    By schotshot in forum Want To Buy...Need help!
    Last Post: 05-26-2009, 02:53 PM
  4. Newbie- 3 Phase Power Question
    By KOzOK in forum General Electronics Discussion
    Last Post: 12-18-2008, 01:27 PM
  5. 1 phase Vs 3 Phase power what is the difference?????
    By KustomKoncepts in forum Commercial CNC Wood Routers
    Last Post: 11-17-2007, 11:34 PM
