Results 1 to 2 of 2
Thread: how to determine stepper motor wiring
    Apr 2011
    Have a 6 lead stepper, can not find data sheet. Coil 9.2ohm
    I have isolated 2 groups of 3 leads using a ohm meter.
    the first set from left to right
    brown, white, blue
    Ohm reading
    brown to white is 9ohm,
    brown to blue 20ohm
    white to blue 9ohm
    can someone explain the wiring based on those readings? which wire would the power input if I was using 12v power supply?
    Jan 2006
    If you are using a bipolar drive, you would connect brown and blue and insulate white.
    If you are using a unipolar drive, you would connect white to 12V and brown and blue to your drive.
    Matt
  1. Newbie- stepper motor wiring help
    By Hersirsmiley in forum Controller & Computer Solutions
    Last Post: 08-05-2010, 01:39 PM
  2. Need Help!- Stepper Motor wiring
    By nenetwork in forum Stepper Motors and Drives
    Last Post: 04-05-2009, 05:32 AM
  3. Stepper motor wiring
    By smitty in forum Stepper Motors and Drives
    Last Post: 03-05-2005, 05:58 PM
  4. Bad stepper motor ??? How do I determine?
    By thuffner3 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 12-16-2003, 12:14 PM
