Having an issue with an air leak when the carousel pot is rotated into postion for a tool change.
There is a constant leak of air, which likely means a broken line, however we do not see an easy access to the cylinder.
The machine is a DMV 500, has a 30 tool carousel. The carousel is mounted on the machine and is a large aluminum casting, with the tool pots bolted ont the casting.
Has anyone had experience with this repair??
