Results 1 to 4 of 4
Thread: Transformer Suitability
    Jan 2006
    I purchased an induction heating machine requiring 3 phase 440 volts.
    I have 600 volt supply in the shop which normally measures 575 volts.
    A pre-used transformer of 600 volt to 480 volt is avalable at a reasonable price.
    Any suggestions if this transformer can be used for this machine?
    As per the transformer ratio, from 575 volt I will get 460 volts.
    From 440 volts it is 4.5% higher.
    Is it permissible to apply 4.5% higher voltage to the machine?
    RRossey
    Dec 2003
    Most industrial machinery have a ±10% supply tolerance.
    Jan 2006
    Thanks Al.
    Looking at some listings, for some transformers it is mentioned DELTA for primary vopltage.
    Is there specific application for transformers with Delta or Star connected primary windings?
    RRossey
    Dec 2003
    Not many are star primary, if a neutral is needed than you would need a star secondary.
    Otherwise the common configuration is Delta/Star.
  1. Tormach be suitability
    By Brains in forum Tormach Personal CNC Mill
    Last Post: 08-08-2009, 07:49 PM
  2. HPDE Suitability For Gibs
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 06-04-2008, 06:09 PM
  3. Suitability of G Code for extruders
    By Bhima in forum G-Code Programing
    Last Post: 05-24-2007, 01:58 PM
  4. DC motor suitability?
    By QSIMDO in forum Industrial Hobbies (Support forum)
    Last Post: 04-15-2007, 11:14 AM
  5. Stepper Motor Suitability?
    By unicorn13 in forum Stepper Motors and Drives
    Last Post: 01-08-2007, 05:36 AM
