- Solenoid Cleaning Help
Can someone push me in the right direction please? I know I saw a how to on cleaning solenoids on here somewhere and now I cant find it for the life of me. Thanks
I have not had much luck cleaning them. I've been replacing mine for some time. Recently I cleaned it with a little compressed air can and reinstalled them. So far they work fine. Shouldn't be that complex actually, just clean each component carefully with the lubricant cleaner an abrasive pad, light brush or rag. The abrasive pad or brush will help break it loose with the cleaner if there is dirt or grime stuck in an area. Otherwise, the soft rag works well with the cleaner.
- You may not post replies
- You may not edit your posts
Forum Rules
