Problem Is it possible to disassemble/reuse these Heidenhain connectors?
Results 1 to 6 of 6
Thread: Is it possible to disassemble/reuse these Heidenhain connectors?
    Nov 2012
    Default Is it possible to disassemble/reuse these Heidenhain connectors?
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: Is it possible to disassemble/reuse these Heidenhain connectors?
    one thing for sure, they did not solder it with that metal enclosure installed, I think you can find a way to open that and resolder every wires on it, cut them shorter of course then resolder everything and re use it.
    Nov 2012
    I know that they were assembled after soldering, but the fact that I cannot find any kind of release tab or setscrew makes me think that they weren't designed to come apart after assembly.
    Apr 2016
    United Kingdom
    Found on another forum:-
    Figured it out eventually,
    I had to remove the clamp at the end of the plug preventing the wires from getting pulled out
    then screw the plug back into the socket
    then with a spanner (19mm) the rear can be unscrewed (normal RH thread)
    after removing again from the socket, the plug can be separated and is ready to be soldered.
    I did try to post a link directly to the forum, but it appears to get blocked.
    Anyway, hope this helped.
    Nick.
    Nov 2012
    Quote Originally Posted by nick952 View Post
    Nick.
    Man! Do I ever owe you one! Thanks a ton.
    Dec 2011
    Hungary
