Need Help! HSD ES919 Spindle bearing removal help..
Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: HSD ES919 Spindle bearing removal help..
    Aug 2015
    Default HSD ES919 Spindle bearing removal help..
    Hi everyone, first post but I've been lurking around for a while and enjoy reading on the forums here.
    I'm in the process of disassembling an old (circa 1997) HSD ES919 spindle to clean it up and rebuild it. I've managed to get the spindle shaft with the bearings attached out of the spindle body as per the manual for changing the shaft kit but am not sure of the best way to proceed from here...
    This spindle is very well made and so far there has been a relatively simple process for removing each component. I'm sure there is an equally well thought out method for removing the bearings but it isn't documented in the standard manual.
    Does anyone have any experience with these spindles and how to proceed from this point?
    The only things I can notice are an Allen key slot in the top of the spring retaining piece and a similar slot inside the top of the taper. As well as some points on the external part of the taper which line up with the outside flange that could be used to unscrew something's at that end...
    I have included some photos of the shaft as sits and any help would be very much appreciated!
    Sent from my SM-G900I using Tapatalk
    Mar 2003
    Default Re: HSD ES919 Spindle bearing removal help..
    We used to pay HSD about $2000 to rebuild ours back then. Sorry, but I don't know how to get it apart. The piece on top is probably a nut, and probably left handed?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Gold Member
    Jan 2005
    Stepping3D
    You need to make or get the special wrenches needed to take it apart, there is already damage done to one part, that is now unusable for a high speed spindle like this, you can buy a replacement spindle Rotor assembly for these Spindles, that is expensive option though, you can not damage any part, of the rotating parts of this spindle, any damaged part or parts will be not usable
    Attached Thumbnails Attached Thumbnails HSD ES919 Spindle bearing removal help..-hsd-spindle-repair-png
    Mactec54
    Aug 2015
    Hi, Thanks for the responses I really appreciate it!
    mactec54, I had noticed the damage to a couple of the parts, it looks like someone who had this spindle previous to me had tried unsuccessfully to take it apart already...
    I have a lathe at home and I was considering attempting to make replacement parts but I'm not confident I can get the tolerances needed.
    I'm going to ask a shop nearby how much they'll charge to make some replacements so I'll see what they say first.
    Do you know by any chance if that part is left or right hand thread? Do I have to remove the draw bar and spring?
    The manual is pretty specific about avoiding that, however that is probably because they consider this part to be out of most people's comfort zone...
    Thanks for the help and advice I'll get the right tools and update the thread when I've made some progress.
    Sep 2009
    romania
    Cool Re: HSD ES919 Spindle bearing removal help..
    Aug 2015
    Thanks a lot everyone for your help! Turns out that particular thread is a normal right handed thread. It was absolutely crazy tight and took a lot of heat and effort to get it off...
    Restoring a 20 year old spindle is a lot of work it seems but it's proving to be a lot of fun too.
    This is a really well used spindle and so now starts the process of trying to get this thing back to original spec.. or with a bit of luck better..
    Here's a few photos of the various parts, many of which are really worse for wear..
  7. #7
    Aug 2013
    which thread was right hand? i got the smaller nut off that retains the upper two bearings, and that was left handed. was yours right handed, or are you talking about the lower larger nut that retains the lower/larger bearings? i'm trying to remove the lower nut and i want to make sure i'm turning it the correct way
  8. #8
    Aug 2015
    Quote Originally Posted by danielwilcox View Post
    Hi Daniel,
    Top bearing retainer as you say was left hand thread.
    Regarding the nose bearings there is two retaining nuts to remove, first one which you remove during disassembly is the one that screws into the bearing housing and it is indeed left handed as well. It also has one or two set screws holding it in place which are screwed through the outer edge of the bearing housing. The second one is the nut which screws onto the spindle shaft and this is the one which actually holds the bearings on the shaft, this is normal right handed thread. Mine was extremely difficult to remove, I first had to heat the whole lot up and then slightly tighten it crack the nut and then quickly remove it before it cooled down. Your mileage may vary, mine was an abused spindle that's about 20 years old so was stuck tight, after removal I inspected it and found the threads were galled, I have since re-machined it and am going through the GPG process currently.
    Good luck getting your's off, I'm sure it won't be as difficult but I'll keep my fingers crossed for you anyway.
  9. #9
    Sep 2012
    zn
    Im so happy to find your photos of the hsd spindle! I am trying to get the top bearings off to clean/replace. How do you lock the drawbar tube to undo the draw bar spring nut on the top? And is this needed ro get the top two bearing off. Also is it normal right hand thread?
  10. #10
    Aug 2015
    If you look up the cone of the spindle you will see a Allen key slot and two divots. This is the set screw which holds the position of the clamp vertically and the divots can lock the clamp in place while you remove the draw bar and springs. I'll check what hand thread it is when I get home tonight if you like but I'm pretty sure it's right hand. Good luck, just take your time and it will come apart without to much issue.
  11. #11
    Sep 2012
    zn
    Quote Originally Posted by Stepping3D View Post
    If you look up the cone of the spindle you will see a Allen key slot and two divots. This is the set screw which holds the position of the draw bar vertically and the divots can lock it in place while you remove the top nut. I'll check what hand thread it is when I get home tonight if you like but I'm pretty sure it's right hand. Good luck, just take your time and it will come apart without to much issue.
    Awesome. Did you make a tool to lock into the divots?
    Dose the allen key setscrew adjust the spring/drawbar tension?
    Have you found replacement bearings and do you mind sharing type and source?
    I will measure and draw all the parts and threads once disassmbled and upload here for future refrence.
    Thanks for uploading the photos and process.
  12. #12
    Sep 2012
    zn
    Some photos from tear down.
    Bearings are snfa 60x35x14 vex35 sq5ceDD 15deg high presicion abec 5 angular contact bearings. 2.5um ecentricity markings on inner race. 1um and 0um on outter race.
    I removed bottom bearings with heat and press cleaned them and regreased them they seem ok but after assembly there is 0.04-0.06mm of run out at the other end of the spindle on the back bearings. 0.005mm or 5um or less is spec.
    I cant get the top bearing nut off or the draw bar out. Not aure if i need to take the draw bar out before the nut will come off.
    Bottom Outter retainer nut= left hand thread
    Inside bottom retainer nut= right hand thread
    Top retainer nut= lefthand thread?
    Top draw bar spring/encoder hex screw= right/left?
    Bottom draw bar hex scew =?
    Need alot of special tools. I made most of them from aluminium and steel pins.
    I need to get the back bearings off and inspect if this is the source of my run out.
    The back bearings have spun in the housing and there looks like heat damage so possibly the problem.
    Attached Thumbnails Attached Thumbnails HSD ES919 Spindle bearing removal help..-20170314_202306-600x1067-jpg   HSD ES919 Spindle bearing removal help..-20170316_160741-600x1067-jpg   HSD ES919 Spindle bearing removal help..-20170314_202336-600x1067-jpg   HSD ES919 Spindle bearing removal help..-20170316_160114-600x1067-jpg
    HSD ES919 Spindle bearing removal help..-20170409_161448-600x1067-jpg   HSD ES919 Spindle bearing removal help..-20170409_161813-600x1067-jpg   HSD ES919 Spindle bearing removal help..-20170410_210006-600x1067-jpg   HSD ES919 Spindle bearing removal help..-20170410_213730_crop_597x597-jpg
