BEST LUBRICANT FOR SCREW DRIVE
Results 1 to 15 of 15
Thread: BEST LUBRICANT FOR SCREW DRIVE
    Jan 2012
    Default BEST LUBRICANT FOR SCREW DRIVE
    Howdy . . . . . .Can someone tell me the "BEST" lubricant to use on a screw drive? Also how many hours of use between cleaning and re-lubricating?
    Never seen anything in writing.
    Thanks in advance
    Jim
    Grapevine, TX
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: BEST LUBRICANT FOR SCREW DRIVE
    What type of screw and nut?
    UCCNC 2017 Screenset
    Jan 2012
    Sorry . . . . . I don't know. It's a MultiCam 22 Plus CNC router.
    Community Moderator wendtmk's Avatar
    Dec 2005
    What Gerry means is it a ballscrew, Acme thread or something else?
    Mark
    Jan 2012
    They are ball screws.
    Mar 2003
    Shelby Township
    We use Kluber GL261, and our automatic lubrication greases them every 3 hours of run time.
    We also have a ballscrew with a spinning nut, that get's greased once/week.
  7. #7
    May 2010
    Quote Originally Posted by ger21 View Post
    I've got a 6040 Chinese CNC and probably have Acme screws. Can this Kluber GL261 be used for these also? What's so special about Kluber GL261 that made you chose it? I don't think my machine has ever been greased, I presume it's a necessity?
  8. #8
    Mar 2003
    Shelby Township
    It's the recommended grease by the manufacturer of the machine. We even buy it from them.
    I use pneumatic tool oil on the acme screws on my homebuilt machine.
  9. #9
    May 2010
    I'm starting to think my screws are ball screw type.
    I'll look into Kluber, I'm surprised you use them, they don't look to be widely used in the US. In Australia they are only in Syd.
    Attached Thumbnails Attached Thumbnails BEST LUBRICANT FOR SCREW DRIVE-20161205_224720-jpg
  10. #10
    Mar 2003
    Shelby Township
    Yes, those are ballscrews.
    We have an Italian machine, and it's what they sell and recommend.
    Be aware that Kluber grease is very expensive.
    Mobil EP1 is a much cheaper alternative.
  11. #11
    May 2010
    Looks like the expensive option is cheapest. Klube sell small quantities of their stuff, I'm not able to find small quantities of EP1, sold in barrels only.
    What about for linear rails, I'm reading oils should be used for these.
  12. #12
    Registered jfong's Avatar
    Apr 2004
    Quote Originally Posted by Atomic_Sheep View Post
    https://www.ebay.com/itm/122101643302
  13. #13
    Mar 2003
    Shelby Township
    We use the same grease for our linear bearings and ballscrews.
  14. #14
    May 2010
    Great thanks.
  15. #15
    CyanWestley's Avatar
    Sep 2017
    Russia
    White lithium grease I think is the best, especially in a convenient aerosol can. It's fortified, durable, non-staining, provides superior friction reduction between comparable or different materials than other lubricants. Will not run, clean off, or freeze and does not gum up or cake on used surfaces. A good choice for use on all moving components found on domestic, commercial and commercial garage doorways, gates and electrical operators, including, rollers, hinges, bearings, springs, cables, roller string, locks, latches, etc.
