| Machinist Feedback Post your experience with members that have fulled your RFQ requests. |
| The controller is an cnc 8025T I have an bar between centres and i want to make the end zero, do i touch the end for z zero and known dia for x zero.In the manual it says call up tool number then x. Do i type in the dia of the bar or machine dimensions and the same with z . It also says about tool shape and tool nose comp also i and k. I think i am looking at this and cant see the wood for the trees |
| Tool setting (assuming you will use more than 1 tool) and part setting are slightly different. I believe the 8025 works like my 8040. You should be able to set your values the same way as using a DRO. Touch end of part. Press Z. input 0. press enter. it will ask if you want to do this or are you just a dumb a$$. press enter again. Z should now read 0. Do X the same way only inputting the size of your reference diameter. If you need to set up more tools relative to this tool you need to use the tool setting function.
| The machine has a manual tool changer as the machine is only used for roughing out (old machine,job is 66 inches long 9inch dia off centre turning) for grinding .At the moment i am to busy on other jobs but i will try to zero the tool sometime next week .At the moment the machine is only used for one particular job so i,ll have to try it before the job comes in again Thanks for the information Darebee i really appreciate it i,ll let you now how i get on sometime next week. |
| Even with a manual tool post, with drop in style tool holders you may still wish to set tools if doing more than one part. The Fagor manuals are not so good IMO. The explain the exact control functions ONLY. There is no explanation of the sequence of steps one might take to produce a part. I feel it should be more in depth and have better translation from the native language (Italian?). This sounds similar to my control - mine shows this all graphically - does yours? This sounds complicated in this writing, but in my experience is very quick and easy.
| cheers darebee this sounds like the right method and the manual is rather confusing.I know i,m jumping the gun a bit but with the canned thread cutting ,after finnishing if thread is to tight, if i remember rightly you cannot re-run the cycle slightly deeper as i will not pick up at the right point p.s. Went on google earth to look where stratford is looks a nice place to live, also your company,s website,we are smaller but simular type of work |
| Help needed on FAGOR controller | CNC_Geek | G-Code Programing | 5 | 10-09-2011 02:42 PM |
| fagor 8025-ms controller problem | jcarls | Fagor Automation | 4 | 04-06-2009 02:42 PM |
| Fagor 8040 Controller | cjels | Want To Buy...Need help! | 3 | 02-20-2009 12:34 AM |
| FAGOR Controller Tool Radius Problem | Kiwi | Fagor Automation | 6 | 06-16-2006 10:48 PM |
| FAGOR 8055M 3Axis Controller | Kiwi | Fagor Automation | 8 | 11-16-2004 03:53 AM |
