Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Machinist Feedback
Machinist Feedback Post your experience with members that have fulled your RFQ requests.
Old 11-17-2009, 04:01 PM
dek dek is offline
dek is on a distinguished road
Unhappy help cnc programing
Cant remember the start lines on basic program for a fanuc controler on a lathe. I have a small silver book on the canned cycles but ive mislaid my basic programing notes as it was a few years ago when i had training.Can anybody help please.
Old 11-20-2009, 04:16 PM
Paul in OK is on a distinguished road
This any help?
Oxxxx
/G28U0.
/G28W0.
N0001M8G99
T0200
M42
G96S0360M3
G0X??Z??T0202
Old 11-20-2009, 04:43 PM
kimpgray is on a distinguished road
you need to state metric / english ? G20 G21 or if an old machine G70 / G71 71= metric absolute G90 or incremental G91 then you need a datum !!! FIRST RULE OF ENGINEERING ? ESTABLISH A DATUM ! will this be under a G54 X / Z ? I use
G71
G90
G54
X ???? Z ???
I hope this helps , if not you are welcome to ask
Old 11-20-2009, 06:26 PM
g-codeguy is on a distinguished road
Which control? What lathe? It can make a difference. I see you are in the UK. G20/G21 should already be set to metric by default, so no need to program this code unless you are going to switch back and forth between the two. Highly unlikely. Don't you have a manual for the lathe?
Old 11-21-2009, 01:28 PM
dek dek is offline
so my program might start (toolpost in front not back)
P9100 (prog no)
N10 G21 (metric)
N20 G40 G00 X400 Z200 T0100 (toolno no comp tool change in safe position) M03 (spindle on anti)
N30 G41 X60 Y2 T0103 M08 (tool comp on coolant on) start point of canned cycle
then program canned cycle i,e, G72(longtitudinal area clearance)
