Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Machinist Feedback
Machinist Feedback Post your experience with members that have fulled your RFQ requests.
Old 10-20-2009, 03:51 PM
bb_24_1 is on a distinguished road
Question Need Help with Stainless 300 series
I am trying to profile cut through 0.063 thick 300 series stainless. I cannot use a cutter any bigger than 0.25. Can anyone offer type of cutter with recommended speeds and feeds? Any help would be greatly appreciated.
Old 10-20-2009, 04:41 PM
beege's Avatar
beege is on a distinguished road
Definitely a lefthand spiral righthand cut or downcut router (stub would be best). Depending on how you secure the part, and how many flutes you have, I'd say 6000 RPMish and .0015" fluteload. Coolant? What kind of machine are you using?
Old 10-21-2009, 08:10 AM
Beege,
I am using a Cincinnati five axis mill. (OLD) My max spindle rpm is 3000. I have tried 2 flute and four flute carbide and cobalt endmills. We are holding the formed part on a steel tube base with a with a fiberglass top vacuum fixture. We are using flood coolant. Is there any certain brand of cutter and or type you would recommend? Example carbide, hss etc? Thank you for your quick response.
Old 10-21-2009, 08:27 AM
beege's Avatar
Well, 3000 RPM, and 1/4" carbide is going to chip out. Carbide needs speed. So I'd go with cobalt HSS if you can find it. Onsrud is a popular maker.
1400 RPM, 3.6 IPM to start with. It's going to be slow.
303 stainless cuts easier than 304, which is easier than 316. 316 will work harden if you go too slow, and will be difficult to cut after that happens.
Old 10-21-2009, 08:36 AM
THANK YOU!! I will try this immediately.
Series 2 cnc 2 hp motor on a series 1 bridgeport? CATCH22 Bridgeport and Hardinge Mills 1 11-08-2008 09:18 AM
Need Help!- 300 series stainless, .020 thick, 40-45RC gearsoup Want To Buy...Need help! 0 02-29-2008 10:37 AM
304 stainless on vf-2 jprobst Haas Mills 6 06-12-2007 08:28 PM
What is the Difference between 6000 series aluminium and 7000 series Kosta1234 General Material Machining Solutions 3 11-19-2005 09:04 AM
