Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Machinist Feedback
Machinist Feedback Post your experience with members that have fulled your RFQ requests.
Old 05-03-2009, 03:34 PM
malirami is on a distinguished road
NEDD HELP PROGRAMING TO CUT A THREAD ON A CNC MILL
I need help. I'm trying to mill a thread on my cnc mill with a FANUC 11M MODEL A Control and I have this alarm :
PS 186 ILLEGAL PLANE SELECT . Do I have to change the way that I'm programing?The subprogram is:G91 G02 I0.500 Z-0.125 F10.0
Old 05-03-2009, 10:21 PM
Superman's Avatar
Superman is on a distinguished road
Fanuc and Okuma are similar
We have to state the I and J on a line doing full arcs
Suggest placing J0. on your line in the subs
I am also assumming you are in the G17 (XY) plane
Old 05-04-2009, 12:20 AM
Smile Thanks Superman
Thanks , I'm going to try that and Yes I,m using G17 I should have to change that?.
Old 05-05-2009, 10:43 AM
broby's Avatar
broby is on a distinguished road
If you do not program I or J the controller will assume that the value for them will be 0 (zero), i.e. no need to program I0.500 J0 as J0 is assumed.
I would suggest that your problem is that you may not have the helical move option on your control, thus explaining the reason for the Plane error.
Even if you do not have the helical move option, you should still be able to program arc moves on the XZ or YZ planes using the G17 G18 G19 plane selection commands.
Old 05-05-2009, 11:40 AM
I think so , because I have programed on other machines with different controls and never had a problem.On this one I tried with G18 , G19 and I made the program with GIBBS CAM too but I get the same alarm.
Old 05-05-2009, 06:13 PM
Superman's Avatar
a quick check,
program an arc using X,Y I, J
prove that it runs
now add a Z to the block
We have one machine that interpolates only in 2 axis, ( cannot ramp on arcs )
Old 05-05-2009, 11:51 PM
I tried something like that , but let me see again.thank you superman.
Old 05-06-2009, 11:54 AM
chopkins is on a distinguished road
Try programming 1/4 circles.
Takasaya mills will only spiral 90 deg or less.
This should work.
Old 05-06-2009, 03:30 PM
ok, let me try thta too.
Old 05-06-2009, 03:33 PM
  #11   Ban this user!
Old 05-06-2009, 04:57 PM
jimmytightpants is on a distinguished road
on the mill I run if we want to cut an arc while moving in the Z we have G2.1/G3.1 instead of G2 and G3. see if your machine has something like that.
  #12   Ban this user!
Old 05-07-2009, 08:39 AM
OK.
Need Help!- Programing a parabola on mill roger_e General CNC (Mill and Lathe) Control Software (NC) 6 03-16-2009 07:48 PM
programing a 1" NPTF ID thread 69ss396 Haas Lathes 1 11-27-2008 01:06 AM
Thread mill external NPT thread cutting edge General Metalwork Discussion 11 09-15-2008 09:33 AM
THREAD MILL dpark1 Mastercam 3 03-06-2008 06:02 PM
MACH 1.90.065 "Nedd port and pin settings over60 Mach Mill 8 08-07-2006 08:32 PM
