| Machinist Feedback Post your experience with members that have fulled your RFQ requests. |
#13
| Note about that mill - it has a 6 speed geared head. The motor will always be providing peak power. Also like the X3 - these gears are noisy. This is a runt copy of the IH mill (which I have) it will likely have a more rigid column than an X3 (have one of those too). I am doing the CNC conversion on the X3, but the IH is in the larger Bridgeport size class and I'll keep it with its DRO as a manual machine. |
#15
| Pobanion, Posting "You Tube" video's may curb the rumors being passed around about the performance of the machines you sell. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
#17
Please also make sure the specs on your Website are complete and correct. I have a feeling they are not doing the best selling job for your machine. Maybe you would like to POINT OUT the advantages of yours over the X3. CR. |
#18
| Thanks for the feed back CR... But all the specs on my site are correct. As for the completeness goes, that is kind of a function of what information a particular individual is looking for. I try to have the most common specs available for everyone. If someone needs additional info, I would be happy to look that info up for them if they request it. And if I get a lot of requests for the same bit of info, then I will be happy to post it. I have had calls/e-mails in the past for specs that I would not consider standard and I am always happy to provide them. I don't think it was ever my intention to directly compete with one specific model (the X3 for example). The specs are available to anyone who does want to make a comparison though. And again if there is something else anyone needs to know... All they have to do is ask. ![]() Thanks, Pat |
#19
| Size of table: 20.5 x 6.25" Y axis travel: 6.25" X axis travel: 12.5" Motor: 0.5 HP 110V 1 Ph Number of speeds: 6 Range of spindle speed: 115-1700 rpm Spindle travel: 3.375" Spindle taper: R8 Drilling capacity: 1" Max mill capacity(End/Face): 0.75/2.5" Max Dist. spindle nose to table: 17.5" Dist. spindle axis to column: 8" Swivel angle of headstock: 90° Net/gross weight: 396/550 Lbs Stand sold separately -18% Details SKU SKU16135 Weight 550.00 lbs Price: CDN$1299.99 So motor is 1/2 HP? Spindle travel is actually QUILL travel. What is HEAD (Or Z axis) travel? So this machine weighs BOTH 396 and 550 pounds? Is that a heavy shipping crate or what? ![]() CR. |
#20
| Yes the motor is 1/2 HP. The Z travel is listed as... Max Dist. spindle nose to table: 17.5" I listed the 550lbs just as a kind of average. Most of the machines get shipped with a stand packaged with it so the 550lbs includes the weight of the stand and the crate. I repackage them before I ship them out because the factory crates are pretty thin. I use 7/16 OSB on a 2 x 4 crate frame which is a little on the heavy side but a lot stronger than the paper thin factory crates. I have never had any trouble from my shipper with what I list on the BOL as far as the weight goes. If you are interested in the exact weight of the machine, the stand and the crate I would be happy to look it up for you. |
#21
CR. |
#22
| pobanion Also add a few more up close and full pics from different angles for each model, the stock "publicity" photo only goes so far. Perhaps with a Kurt 6" vise for scale. BTW major Kudos for re-crating the machine before final shipment. I ordered an IH mill and while the machine arrived much of the crate did not. |
#23
| For anyone who is interested - I purchased the MD003+ from Paul at MTW, and while I haven't run the machine yet (as it's still in pieces from the move to the basement) I can personally attest to the quality of the shipping crate. It arrived in pristine condition, and I actually had to hatchet off a corner of the box to get my prybar in there - 2x4 uprights, on an extremely sturdy pallet, and a couple of hundred nails! It took quite some effort to get into it! Hth. ~ Ian |
| I have purchase a 4axis CNC converted SIEG SUPER X3 from "SyiL" | CrazyRonny | Syil Products | 369 | 08-30-2008 11:25 PM |
| BattleAxe "aka" Ball and Chain "aka" the wife. | ZipSnipe | CNCzone Club House | 48 | 05-18-2008 09:53 AM |
| G320 "common" or "+5vdc" why do they vary? | beezerlm | Gecko Drives | 3 | 01-12-2008 04:00 PM |
| Sieg super x3 "im buying it" | Bugpac | Benchtop Machines | 2 | 01-19-2007 09:04 AM |
| Vertical system "jerks" and "bangs"?? | REVCAM_Bob | Servo Motors and Drives | 5 | 06-12-2006 09:09 AM |
