| Machinist Feedback Post your experience with members that have fulled your RFQ requests. |
| foremans giving me hell what smpm or sfpm do you use with carbide tipped endmills i.e p20 or toolsteel |
| Many insert manufacturers will recommend a particular insert for a given material, and will then give a range of speeds ( sfpm or smpm ) and feeds. Machinerys handbook should give you a basic starting point for most materials. Here is a link to an online speed/feed calculator that has speeds and feeds for different materials. http://www.whitney-tool.com/html/cal...SpeedFeed.html |
| depends on what your trying to achieve.... roughing, finishing? tolerances and surface finishes will have a big impact on how aggressive you can be....eg: in 4140 i run a 3/4" dia. indexable carbide 2 flute emill at .060" doc at 2400 rpm & 36 ipm, when i'm finishing with a 1/2' DIA. solid carb 4fl emill in the same mat'l i run at 750rpm at 6.0 ipm to achieve +-.0005 x 2" dp. & re-run the tool to take the deflection out. works great! and i get the most mileage out of the tools....the ruffing tool is cooled by air only, finisher with coolant. |
| thanks tc26 you dont know how much thats helped me the chart ive been using only gives solid carbide feeds the whitney tool company site is really useful |
| what should my speed and feed be for cutting 304 stainless with 6 inch saw blade .125 thick using a vertical machining center |
| You need to know how many teeth in a cutter to calculate feed. |
| Speeds And Feeds | John H | General Metalwork Discussion | 10 | 12-08-2008 10:10 PM |
| Need some help with speeds & feeds | ldkell_2000 | General Metalwork Discussion | 6 | 03-01-2008 11:35 AM |
| Speeds and Feeds | frogger | Haas Mills | 20 | 02-26-2008 03:42 PM |
| Need Help!- speeds and feeds | rodzilla | Benchtop Machines | 3 | 02-19-2008 11:30 PM |
| Help! with Feeds and speeds please! | sjotime! | Visual Mill | 3 | 02-13-2008 01:56 AM |
