Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Machinist Feedback
Machinist Feedback Post your experience with members that have fulled your RFQ requests.
Old 02-09-2008, 01:40 PM
doggerbite is on a distinguished road
stabilizing lg bar stock
We machine large inco bar stock (6" dia) x 6' long and we always have problems with th bar moving around in the power chuck, we have tried wedges to support the other end of the bar but most times the wedges vibrate out and we end up spending time to stabilize the bar again. We make small seals from this bar stock so we are always moving the stock out for the next seal to be made. Anyone got any ideas for stabilizing the end of the bar? Most times the stock is inside the spindle tube.
Old 02-09-2008, 02:41 PM
Runner4404spd is on a distinguished road
spindle liner?
Old 02-09-2008, 02:44 PM
Make bushings that go inside the spindle; OD just a neat fit in the spindle holw, ID just a small clearance on the bar stock. They can be spaced several inches apart with larger ID separater tubes and retained with a flange attached at the far end of the spindle,
Old 02-09-2008, 09:37 PM
HuFlungDung's Avatar
Moderator
Need a quote, eh? How's this:
"Ask not, with whatall shall I shim this contentious bar, but rather, with what shall I adapt my oversize spindle".
Old 02-17-2008, 01:47 AM
Motorcoach1's Avatar
Motorcoach1 is on a distinguished road
Had the same problem years ago on a johnson klob terret, we had to make up a roller bed to support the bar in feed end and a ring with 3 rollers to stablize the end till we fed most of the stock in and machined off what we needed , low RPM's
7/12 stock to cnc LeeWay Vertical Mill, Lathe Project Log 6 08-30-2010 07:19 AM
Stabilizing power supply Goose80 General Electronics Discussion 7 01-12-2007 02:35 PM
G100 Out of stock??? aghobby Gecko Drives 2 11-27-2006 07:14 AM
Who has stepperes in stock? LeeWay DIY-CNC Router Table Machines 23 03-27-2006 09:23 AM
head stock and tail stock chucks mocnc DIY-CNC Router Table Machines 3 10-19-2004 10:16 PM
