NC on one switch to COM on the next one. And so on...
I need to wire my limit switches in series so if one is tripped it shuts all down
UCCNC 2017 Screenset
Ok hope I got this correct but can I do this with 4 switches or am I better off just using 2 switches for X and 2 for y?
There are some old threads on the subject here http://www.cnczone.com/forums/attach...8&d=1395137650 .hope this helps I always google to find answers these guys usualy have done it many times.
if you have enough pins on your breakout board for wiring limits individually, then that is the way to go. This way each switch activates one pin and the controller can know and tell you which limit switch is tripped. This would require 6 pins to be used for a 3-axis machine for limits (+X, -X, +Y, -Y, +Z,-Z)
Wiring them in series is done when there are not enough pins. In this case do what you can. If you have 3 pins that can be used for limits then do one pin for each axis. For example +X and -X wired in series on one pin and so on
You can wire all 6 of the limits in series and connect to one pin if that is all you have available. Depends on the setup.
I personally would do all individually if possible and enough pins available, and reduce from there.
https://hobbycnc.com/faq/ Scroll down to Limit Switches I will also try and paste the schematic here I have
I would like to thank all of you good people for the help, I have the limit switches hooked up in series sure gets rid of a lot of wire, againThank you and God Bless
Jim
Cushing, WI
