Hi Guys
I have a brand new Fanuc Robodrill with a Fanuc Trunnion factory installed.
My problem is when I tilt the table.
In 0° I align it perfectly, but when I tilt in 90° and 270° and facemilling it, it does not make those sides parallel to each other.
I believe it is some adjustment of the table that is necessary. The 2 points in the bearings of the trunnion is in alignment, so it must be the baseplate or something of the table itself.
How is right way to make a complete alignment of the trunnion?
Jacob
Hi Guys
Jacob
If it's brand new get Fanuc to do it as if you do it you will invalidate warranty
Speak to Pascal at Fanuc UK he is the best to advise you
