Sorry guys. I didn't say clearly that when I cut a path from top to middle of the material and rotate the material 180 degrees to cut the same path from below there is a gap as the two paths do not align.
Tdoz
Hello everyone,
I use a 4 axes machine and recently I am having trouble with my Y axis.
I have attached :
1. Photos of how I locate Y zero and Z zero,
2. Photos of where I set the coordinates for the two axes to zero,
3. RhinoCam simulation of a simple test job,
4. G code for the simple job,
5. A picture comparing the codes for the top cut and bottom cut. Please observe that the A0 and A180 portions of the codes are perfect mirror images.
6. A picture of the end result.
It wasn’t having alignment problems like this before. I just don’t know what happened.
Your suggestions will be highly appreciated. Thank you.
Tdoz
Tdoz
