- I'm after a machine similar to the CENTAURO ALFA NC
I've been looking at the 'centauro alfa NC'(pictured above) for some time. I'm attracted to it because of it's small size, as we are tight on space, and it's relatively low cost. It seems ideal for what we want it for, e.g, cutting out hinges and mortices for locks etc.... The only thing that lets it down is that it isn't a full CNC machine. It uses set programs which limits it's uses. I'm sure the machine is capable of much more if it had the right software. Can anyone suggest a similar machine that is full CNC?
- You may not post replies
- You may not edit your posts
Forum Rules
