- Chip tray construction material w. Liquid chilling
Hey guys,
Quick question about what I should construct my chip tray out of. I plan on adding liquid cooling eventually, so I've toyed with the idea of making my enclosure it off sheet metal instead of wood.
The thing with wood is you have to coat with resin epoxy etc. With sheet metal I'd just weld it together.
However would rust become an issue over the long term? I'm not familiar with the coolant being used and if it causes rust to form.
Thanks guys
- You may not post replies
- You may not edit your posts
Forum Rules
