- Chip Recutting
Chip Recutting
This is mainly directed to those who have worked with the Intelitek Benchmill 6000 mill, since that's the machine I'm working with.
As part of my engineering design class, we must develop a solution to a problem. I've decided to look into the issue of chip buildup and recutting in mills. The first step is to get confirmation that this is an actual problem. To this end, I have written a short survey to try and get other people's thoughts. I'd really appreciate it if you took a minute to fill out this survey (it's only 3 questions), and it'd help me out tremendously.
Here's the survey:
Benchmill 6000 Survey
To those who do not own a Benchmill 6000, your thoughts on this issue in the thread below would still be very helpful.
- Chip Recutting
- You may not post replies
- You may not edit your posts
Forum Rules
