- Y axis doesn't go to home position.
Hi guys,
I need help I work on CNC machine 1325 Piranha ATC Syntec 6mb
I came across some issue that I can't resolve myself so I would like to ask you if maybe you could help me.
Basically when I started machine yesterday the Y axis doesn't go to home position it wants to go over its limit.
X and Z axis works fine but when I am trying to put Y axis in home position I am getting this message that all of the axis X Y Z C are positive and negative limit exceeded and last line says MLC Hint 1 R590.1 over travel.
Would you be able to help me, I would much appreciate it
Thanks in advance
- You may not post replies
- You may not edit your posts
Forum Rules
