Coolant Shenanigans
Results 1 to 3 of 3
Thread: Coolant Shenanigans
    Sep 2017
    Default Coolant Shenanigans
    Start this out as I am new to this forum, Hopefully this is the right place for this.
    So we have 2 Mazak Quick turns, one with hyd. fluid and the other W/O. We also have a HAAS VF2 and VF4. Along with 2 manual lathes, 2 manual mills, and 1 Trak V7. Also have WF Wells saw.
    We currently use SAF-T-COOL 475. Out of all the coolants we have tried it has been the only one that hasn't stunk horridly. However due to private company issues we can no longer buy from them.
    I need a coolant that will be good for milling, turning, tapping, drilling, ect. Everything including sawing.
    Here are the brands I have access to;
    ASTRO-CUT
    TRIM
    RUSTLICK
    CASTROL
    MONROE
    STARCHEM
    I would like a few different options as im not exactly sure what we will end up going with.
    Follow this link, if some one wouldn't mind; and tell me out of these products which would work best for us. WE MUST ORDER FROM THIS SITE.
    https://www.travers.com/synthetic-lu...lant/c/298086/
    I have been trying to do my research and I want some more opinions from other shops out there.
    Thank you all for your time!
    Mar 2008
    Default Re: Coolant Shenanigans
    Picocool 5254
    Great stuff. No smell at all even after sitting for weeks in the hot summer. I won't use anything else again.
    Jun 2010
    A lot of aerospace companies have switched to MQL for better performance and better tool life. You might like to read up on it.
    Cheers
    Roger
Coolant Shenanigans
Coolant Shenanigans
