new to aluminium
Results 1 to 5 of 5
Thread: new to aluminium
    Sep 2017
    United Kingdom
    Default new to aluminium
    hi, ive never machined aluminium before and need help!!!
    i want to know the speeds and feeds (formulas) etc for an 80mm facemill with 7 carbide inserts
    any help will be great
    Aug 2017
    Default Re: new to aluminium
    i would run anywhere from 650-1200 rpm with a feed of 18-30 ipm depending on depth of cut
    Jun 2007
    It depends on the carbide inserts you are running. Are you using an uncoated grade that are polished for aluminum. If not then you will not get a good finish. Also lead angle can be important. Finally, I would calculate 1200 RPM @ .15MM per tooth chip load or 1260 per meters per minute feed rate.
    Please let me know what depth of cut you are taking and horse power on the machine.
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    I'd go even faster with the uncoated Alum. tips
    Cutting speed up round the 700-1000 m/min ( Ø80 = 3000 RPM, @ 0.15/tooth x 7 teeth (F3000.) DOC 2mm max , ae=50% (stepover), use coolant to stop the chip weld
    I use a Ø63, 5 tip Octo facemill @ 5000 RPM Fz=0.12 ( F3000. ) flood coolant
    Using just air will always fail due to built-up edge ( chip weld )
    Gold Member
    Jun 2010
    Possibly so, especially with the softer alloys.
    However, pulsed misting (with airblast!) does work well. I use 3 parts kero to 1 part olive oil, 0.5 S pulse every 15 - 30 seconds, depending. This is something you have to tune for YOUR machine. Just keep the cutter slightly wet.
    Cheers
    Roger
new to aluminium
new to aluminium
