- Where to start? The deep end sounds good! New to CNC need advice please
Hello everyone - Thanks for making such informative and helpful forum.
I've already read several posts to get an idea of where to start. Please move this if I'm in the wrong place.
So I want to get in to 5 axis milling of large items. Generally, this will be for composite moulds made from tooling board, MDF and polystyrene with paste.
I've purchased a machine that I will take delivery of in a couple of months. Meanwhile, I am trying to learn as much as I can. I think I have the basics and will keep reading and practicing with CAM software. I currently have a free trial version of Fusion 360. However, I'm not sure that this is the package best suited to me. So - to my questions.
#1 I will never be designing jobs from scratch - I will always receive drawings and designs from a customer. Most likely solidworks models. I will need to plot too paths and compose the G Code. The work will vary from simple square shapes with corners to complex sweeping shapes that I hope the 5 axis will be at home with. What is the best software to do this?
#2 The machine has a NUM controller. I understand that the CAM software will generate code and as a fairly standard controller it should be simple. But I can't understand why it may need someone to edit this - for "dialect". Is that things like coolant and tool changes - neither of which I have.
#3 If I have a drawing and create a wonderful tool path then create code for it - how does anything know it's going to fit on my machine? What is the flow of the machines telling each other the limits of size? I.e. if I send it on a 6 meter X axis trip and it's only 5 - what happens?
#4 What is a wander lead?
#5 What is a setting bar?
#6 The machine has a spindle taper SK30 - where can I find in the UK or Europe holders?
#7 How do I know what is the most suitable bits for each material? Bearing in mind that the hardest thing will be tooling board - 800kg/m3. There are loads of resources for speeds and feeds for metals but not the materials I plan on using.
If anyone can help me with even one of my long list of questions I'll be really thankful.
TIA
Youth
Re: Where to start? The deep end sounds good! New to CNC need advice please
Hello, this is all known many of us have done it already.
(done lotsa' composite layup vacuum molds) header boards, master models monolithic graphite, 5axis trim
Maybe you may need to buy some knowledge and experience in order to get that machine productive and money in your pocket?
5 axis concepts are very straightforward and a little coaching will leap you into production.
Hi bostosh,
Thanks for the reply - good to hear from someone that has experience with a similar style of machining. Do you mean "buy some knowledge and experience" as in employ someone? Unfortunately I'm not in a position to do that. I was hoping I could get some ideas from the forum members here. The aim of the machine isn't to make me money, other things do that. It is something for the future. I plan on playing for several months to learn as much as I can.
I didn't expect a reply to every answer - perhaps a suggestion to one or two to point me in the correct direction. Any thoughts would really be welcome. Thanks again
- You may not post replies
- You may not edit your posts
Forum Rules
