Plasma 5 volts to set off relay to arc.
Results 1 to 3 of 3
Thread: Plasma 5 volts to set off relay to arc.
    Jan 2017
    Default Plasma 5 volts to set off relay to arc.
    So I have my cnc plasma cutter set up and I have the break out board pin 1 firing out 5 volts to a relay switch for the plasma cutter.
    The problem is it wont switch the relay, I guess not enough amps. 5 volts shows on the meter when it should and the plasma cutter fires off when I connect it directly out of the 5 volt usb port.
    But after it goes through the breakout board, not enough amps.
    Wondering if it will fire if I put more amps through the breakout board like a seperate power supply. Having a hard time trying to find a small enough relay switch to work with such little power.
    Any help would be great THanks!
    Dec 2003
    Default Re: Plasma 5 volts to set off relay to arc.
    Without knowing the details but if you need a low current operating device to pick up a relay from 5v then the Fet 2n7000 should do it easily.
    Search here for 2n7000 should bring up some results.
    It is possible your BOB has a opto isolator on the output which will not pick up a relay due to insufficient current capability.
    Here is one http://www.cnczone.com/forums/genera...64477-cnc.html
    Jan 2017
    Thanks I think I got it, they have ones that have to be powered seperatly then hook up the breakout board low power signal to it.
