Trig help- writing a program without cutter comp.
Results 1 to 3 of 3
Thread: Trig help- writing a program without cutter comp.
    Dec 2016
    United Kingdom
    Default Trig help- writing a program without cutter comp.
    Hi folks as title I have to machine a rad going into a rad of the face of some stainless steel. G41/G42 doesn't work as it's in fanuc easyturn. Tool will be a 0.4 rad 35 degree insert
    It's a lathe btw!
    Cheers
    Apr 2008
    Default Re: Trig help- writing a program without cutter comp.
    Are you posting code via computer. If so just offset your drawing with a separate line and just make a separate tool path (put these lines in a red layer so you know it is your offset). This way no math.
    Dec 2016
    United Kingdom
    Quote Originally Posted by davy182 View Post
    I'm writing it on the machine itself, it's a 0.8 rad going into a 1.2 rad and then blending back out to a 0.8 rad
