I think I have solved this problem, but I run into another. This one is ( I suppose) on the software or post processor level.
When I create things for my 4th axis, I use Vectric gadget Wrapped Job Setup and Vector Unwrapped. When I machine it, everything goes well except one nasty groove made by machine in the place where the wrapped job joints.
I made the same design in SolidWorks and imported it to Vectric as STL file……The same thing is happening ( see attachment photo)
When I simulate run on Vectric I don’t see this groove.
This only happens when I run roughing toolpath. Finish toolpath does not follow the groove and it looks like it functions well but can not correct the problem , since the roughing takes too much material making that groove.
(vectric project is clean , but the real piece not)
Any idea what is going on?
Thanx.
