An automatic tool changer would probably nearly double the price of the machine, as ATC spindles are very expensive.1) Their machines do not offer a multi tool changer or auto Z axis zeroing, at least I have not seen this feature, I think I will soon need something like this once I figure out how to use the machine and start making parts. Does anyone know of an add on kit that I could purchase sometime in the future after owning the machine
Automatic Z zeroing is handled by the software. Typically, all that you need is a plate wired to an input, and the macro to control it. There are many versions of Auto zero macro's available for download, and a few for purchase.
Yes, it should be fine.3) Will it be a good enough machine to work 4-8 hours a day 5 days a week?
I think that with chinese machines it's 50/50. You may get a good machine, or you may get a machine that requires a considerable amount of work to make it right. If you get a good one, than yes, you save a considerable amount of money. If not, then not so much.
