- Turner's CUBE Equations
Re: Turner's CUBE Equations
This post seems to come up when looking for dimensions on how to build a turners cube.
The problem is that I don't have solid works and the math doesn't work in a spreadsheet.
So I'll post my dimensions as a starting point if you want to try this. I'm sure you can scale it for other cube sizes.
Cube size: 76mm
First dia: 68.60 at 8.5 mm deep
second dia: 50.5 at 16.5
third dia: 36.5 at 23
forth dia: 23 at 28.5
- You may not post replies
- You may not edit your posts
Forum Rules
