Hello my nane is Heyward and I wanted to know, I am starting school for the cnc field and which machine is use more lathe, mills, or swiss machine's
crawl before you run start with lathes the simplest. You want to be a swiss or a mill turn programmer some day
thanks for the advice because I am starting lathe's but I worked as a cnc operator using thermwood and royce machine's for plastic as a setup tech and I know that the machines are very different. but my Goal is to be a setup/programmer.
View Tag Cloud
Forum Rules
